How much labor in a valve cover gasket change?
Old Mar 2, 2003 | 09:31 PM
Burn_Out's Avatar
I have a bad oil leak on my driver side valve cover and was wondering how hard of a job that is to change the gasket out, thanks.
Old Mar 2, 2003 | 09:37 PM
94 CAMRO Z28's Avatar
Valve covers are easy, especially the drivers side. Probably about 10-15min. job your first time around, once you done it before you could pull it, install the new gasket, and bolt it back down probably within 5min. The gaskets on the valve covers and just a rubber/foam that pops into a recess within the cover, so its not hard at all. As simple as unscrewing four bolts. Hope this helps.
Aaron
Old Mar 2, 2003 | 10:51 PM
Not sure if I had to, but it seems like I remember removing the AIR diverter from the exhaust manifold to get the cover off. It can be troublesome if it is stuck. Definite anti-seize used when putting it back on.
Old Mar 2, 2003 | 11:00 PM
1loudz's Avatar
Someone having a 428 r.w.h.p. car and not being able to change the valve cover gasket, is just not right!
Old Mar 2, 2003 | 11:01 PM
Hey how much are you looking to get for your car?
Aaron
Old Mar 3, 2003 | 12:58 AM
GeneralZ's Avatar
It took me longer to find the right socket than it did to change my both my gaskets.
Old Mar 3, 2003 | 01:40 AM
SVT Killer LV's Avatar
easy s#it man.. do it yourself... you have over 400 rwhp and you need somebody to do that? something doesn't add
Old Mar 3, 2003 | 02:23 AM
blown383's Avatar
I'd charge you a slice of pizza and a can of coke.
-B
HectorM52
Jan 30, 2015 11:34 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Snoman73
Nov 17, 2014 07:22 PM
