How long do plug wires last?
I have a 94Z almost stock(no headers) and 130k miles. I have never changed the plug wires in the 4 years I have owned it. The previous owner did change them once. Is this really good life or typical?
well they should last for a long time unless they get burned up. But if you have been driving it for 4 years i would change them and the spark plugs. Even if you think your car is running fine right now you will be surprised how much better the car will run with a fresh set of plugs and wires.
That is what I plan to do. Given the "pain in the A" factor, I only want to do this once. What do you recomend as far as size and brand? I would like to do the OVC set but I have stock manifolds and dont plan on switching to headers for a long time if at all. Will that set work with a stock setup?
sleeperZ96BT
Jun 5, 2005 09:33 PM
