how the hell do you get teh driveshaft off?
Old Jun 4, 2003 | 01:39 PM
thewinner's Avatar
I have removed the 4 7/16" bolts and those little retainer pieces at the rear ujoint. Its my understanding that you must push the ds into the tranny and then bring it out and down.
This is the first time removing the ds, and its stuck damn good in there. any tips to getting it out? BFH?
Old Jun 4, 2003 | 01:44 PM
madwolf's Avatar
I used a tire iron to detach it from the yoke. Insert something similar between the yoke and u-joing and push carefully. It should come out pretty easy.
Old Jun 4, 2003 | 02:00 PM
teke184's Avatar
mine jsut slid right out, at least as far as coming off the yoke. it slid forward and then took some tugging and pulling to squeeze it down between the torque arm and the exhaust.
you could remove the two bolts on the back of the TA and move it aside to get some more room. that may help
Old Jun 4, 2003 | 02:29 PM
thewinner's Avatar
came out easy when i used a screwdriver on it. thanks guys!
tranny fluid supposed to come out the front a little?
Old Jun 4, 2003 | 02:30 PM
madwolf's Avatar
Yep, that's normal.
Timberwolf's Avatar
yep, put a catch can under the trans tail shaft housing
Formula Steve
Sep 19, 2023 08:31 AM
Nayr
Mar 3, 2023 08:34 PM
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
