How the hell do I get the distributor cap off?
Where do I get this inverted torx socket, I checked sears, autozone, and o'reilleys, who carries this stupid thing.
Well I had an extra torx screw for the TB cover plate.....I just used that and some vice grips....it worked fine.
autozone
Alreayd tried, did not have it.
I bought a set of GM packaged torx bits from O'reilly's. It was the only place that had them(I went to several auto/hardware stores). You might try seeing if they can order them.
I had the same problems finding a socket that would fit. I finally found a SET of torx sockets with the right size in it at Checkers/Schucks/Kragen.
they had them at my autozone
try Sears... i have a whole set of craftsman torx's from there... dont know if your nearest Sears is as big as the one around here though... just my $0.02
Originally posted by Sellmanb try Sears... |
I believe the socket needed is an E4.
