How does this airfoil install?
I got this for $20 shipped....figured I should get one, since besides an underdrive pulley, it's the only bolt-on (I think) I don't have.
http://img.photobucket.com/albums/v6...28/airfoil.jpg http://img.photobucket.com/albums/v6...8/airfoil2.jpg Any idea how it installs? |
Re: How does this airfoil install?
did it not come with any other hardware? usually there is a screw the goes through the back of the throttle body to clap it in place i believe.
I got it used....he said nothing else came with it.
That looks like the kind that sits just infront of your TB, it just sandwiches between it and the lip inside the boot......
IMO it's better used as a paper weight. You won't see any gains by using it... |
Originally Posted by SS RRR
He's full of crap. There is supposed to be a bolt that goes with it for fastening to the TB.
I have the same type and I have it sandwiched in between the TB and the intake elbow, works for me. The two holes that look like screw holes go on the bottom, at least that's how mine is. I believe that's for the IAC. Not sure though. Anyone else?
Wayne |
Wayne |
Yes, there is no other hardware, thats a Jet airfoil. It's just a sandwich type, not the best by any means, but better than nothing.
-Shannon |
Nomad got it. Its a Jet airfoil. It goes in the lip just inside the rubber elbow and then you install the elbow like normal. I have one in my 1LE intake elbow. It should be marked TOP on one side, this is the side that should be up when installed. Its not any worse than the PITA bolt in one.
| All times are GMT -5. The time now is 09:24 AM. |
