How do you test the ICM and coil?
How would I test to see if the ICM and coil were good?
I check with an ohm meter and it showed 5500 ohms across all of the points on the coil. |
Re: How do you test the ICM and coil?
place a screwdriver near the coil tip, crank engine :D
j/k DONT do that... |
Take the ICM to OReily's, they can test it.
As for the coil, I've been told it either works or it doesnt... but its not that expensive to replace anyways. |
Coil is easy, unplug the spark plug wire from the distributor and put that end towards a ground, crank the car and if it sparks a nice blue spark and gives you a jolt, its good.
I already told you how to check them. ICM gets ground on one wire. 2 other wires are connected to the coil and will have 12 volts on them. The 4th wire from the PCM(usually white) will have 1-4 volts AC when the engine is cranking.
Finish your homework and get back to me. Dave |
| All times are GMT -5. The time now is 07:26 AM. |
