CamaroZ28.Com Message Board
-   -   How do you remove the drivers side headers? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/how-do-you-remove-drivers-side-headers-200570/)
WhiteBeast Dec 6, 2003 04:38 PM
Ok, I just finished removing the down pipe and catalytic converter and snapped 2 bolts on the drivers side exhaust headers.
What i am wondering is how do you remove the drivers side headers?
How many bolts are there?
What is the best way to remove the headers?
ibanez6rg Dec 6, 2003 04:48 PM
There's 6 bolts total... I don't know what you're gonna do about the broken bolts though.
WhiteBeast Dec 6, 2003 04:51 PM
Well couldnt i just pull the headers and then drill the broken bolt studs out and rethread some new ones?
ibanez6rg Dec 6, 2003 05:19 PM
I guess you could give it a try if nothing else :)
I've tried doing it once on a small 1 cylinder 4-stroke and it was a pain in the ass.
WhiteBeast Dec 6, 2003 06:51 PM
ok, i removed the exhaust header and now i just have to remove the bolts that were inside of the exhaust header and thread some new ones.
I wasnt talking about the bolts inside of the block, i was refering to the bolts inside of the exhaust header that connects the header to the y-pipe.
So basically all i have to do is remove the old bolts and thread some new ones in....But how do i do this?
Will i have to drill the old ones out and tap some new ones?
97Camaro007 Dec 6, 2003 07:15 PM
Are you talking about the Exhaust Manifolds? Because exhaust manifolds and headers are different.....to me anyways! :D Anyways i wouldn't even worry about the bolts on the exhaust unless you are planning to put it back on....Are you installing headers?
ibanez6rg Dec 6, 2003 11:47 PM
Ohh, I thought you meant you broke the bolt off in the head.
97WS6SCharged Dec 6, 2003 11:53 PM
Why are you removing the exhaust?
WhiteBeast Dec 7, 2003 12:56 AM
I am removing the exhaust manifolds because i broke off the bolts when i was trying to remove the y-pipe. All of my bolts are so rusted that it would be impossible to remove them without breaking them.
So now i am removing the exhaust manifolds to replace the bolts with some nice stainless steel ones.
so tomorow i will be taking on the passenger side exhaust manifold... Any suggestions?
Man...what a pain in the A$$ to try and fix one little bolt when you end up removing every part of the exhaust.
Z95m6 Dec 7, 2003 01:00 AM
Just use a torch to heat up the manifold around the stud then turn the broken stud out with vice grips.
