How do you remove the drivers side headers?
Ok, I just finished removing the down pipe and catalytic converter and snapped 2 bolts on the drivers side exhaust headers.
What i am wondering is how do you remove the drivers side headers?
How many bolts are there?
What is the best way to remove the headers?
ok, i removed the exhaust header and now i just have to remove the bolts that were inside of the exhaust header and thread some new ones.
I wasnt talking about the bolts inside of the block, i was refering to the bolts inside of the exhaust header that connects the header to the y-pipe.
So basically all i have to do is remove the old bolts and thread some new ones in....But how do i do this?
Will i have to drill the old ones out and tap some new ones?
Are you talking about the Exhaust Manifolds? Because exhaust manifolds and headers are different.....to me anyways!
Anyways i wouldn't even worry about the bolts on the exhaust unless you are planning to put it back on....Are you installing headers?
I am removing the exhaust manifolds because i broke off the bolts when i was trying to remove the y-pipe. All of my bolts are so rusted that it would be impossible to remove them without breaking them.
So now i am removing the exhaust manifolds to replace the bolts with some nice stainless steel ones.
so tomorow i will be taking on the passenger side exhaust manifold... Any suggestions?
Man...what a pain in the A$$ to try and fix one little bolt when you end up removing every part of the exhaust.
squarehead
Nov 21, 2014 08:02 PM
Jul 4, 2005 05:00 PM
CamaroZBoy
Sep 9, 2002 10:33 AM
