How do you check 4 a bad lifter
Old Dec 7, 2004 | 07:13 PM
Zjoker's Avatar
I was wondering if anybody knew how to check for bad lifters without taking the manifold off. Also if I have a bad lifter will it throw a code? Help
Old Dec 7, 2004 | 07:30 PM
JBird33's Avatar
Re: How do you check 4 a bad lifter
Pretty sure it won't throw a code. Not positive on that though - is your car clicking real bad, and does it match your revs if that sound is there? Maybe if you gave more info someone with more knowledge than me can help you out more.
Old Dec 8, 2004 | 03:20 AM
Zjoker's Avatar
Well I do have a clicking noise that increases with revs. I have a miss in the idle; hopes this is the info you were taking about.
Old Dec 8, 2004 | 05:41 AM
slopokrodrigez's Avatar
You can check the lifters by simply removing the valve cover. Usually, not always, but usually the noisy one is collapsed and when you push on it, it is mushy and moves. You should check to be sure any nuts haven't backed off. You could also check the lash again. Lash can be done running or off but remember when it's running, it's messy. If you have to change one lifter, don't waste your time, change them all. Be sure to inspect the lifter roller very carefully for lost bearing rollers.
Oh yeah, what oil are you using? I see a lot of people that have used the wrong weight oil and tapping is the result. If you put in a high quality 5w-30, it may quiet down. Try the oil first. Maybe all you need.
Old Dec 8, 2004 | 06:44 AM
teke184's Avatar
by pushing on the lifter do you mean pull the rocker arm and push down on the pushrod?
i think i may have the same problem but on my LS1...
sucks that i have to pull the heads to change lifters!!!
Old Dec 8, 2004 | 12:10 PM
PatriotTA's Avatar
You would be pushing down on the pushrod, away from the rocker arm, I'd imagine.
Another way to check is to take off the valve covers and run the engine. yeah, its a little messy, but you can rig up some cardboard to keep the oil from getting all over your headers or whatever. Watch all of your rockers to make sure that they are moving properly. If one of the rockers is not moving like it should (very little movement) that lifter is suspect.
Instead of taking of both valve covers, put a screwdriver to each valve cover and your ear to the other end, listen to the valvetrain. You can see which bank has the problem, and save yourself half the work.
Old Dec 8, 2004 | 01:40 PM
Compstall's Avatar
BTW, I looked on the GMpartsdirect site last week and stock lifters are only $23.48 per pack of 8.
Old Jan 3, 2005 | 05:49 PM
Pasky's Avatar
Are you serious? I just paid fricken 160 for 16 at O'reilly's.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
