CamaroZ28.Com Message Board
-   -   How do You Change the PCV ? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/how-do-you-change-pcv-316706/)
Spllouder Nov 10, 2004 05:16 PM
OK i bought a new one and wanted to change it never changed one before .
So i dint go messing with it too much . So how u do it ? will i need a new groment too ? Thx :confused: :confused:
ChevyTuffD.A. Nov 10, 2004 05:21 PM
Re: How do You Change the PCV ?
As far I know u just pull it out and put the new one right in there, not that big a deal.
Spllouder Nov 10, 2004 05:54 PM
ok is it on the rh side or left shoeboxs site says lh intake side but his is a 95 ? looks difernt ? its on the rh side in the middle right ?
ChevyTuffD.A. Nov 10, 2004 05:56 PM
It should be on the driver's side of the intake manifold, somewhere in the middle.
shoebox Nov 10, 2004 06:25 PM
LH side in the middle of the intake for a 1994 as well. The pipe feeding it the vacuum may look a little different, though.
Spllouder Nov 10, 2004 11:51 PM
ok i missunder stood ur website shoebox thx . i get you now and ya its a black hose ? So what i do pull on the hose ???
shoebox Nov 10, 2004 11:56 PM
The PCV valve fits into the rubber grommet in the intake manifold. Just pull on the hose and the valve should come out with it.
Mtrhds94Z Nov 11, 2004 05:53 AM
For 94 it's a 'U' shaped vac hose..
AxeGrinder30thZ Nov 11, 2004 06:00 AM
I replaced mine a couple of weeks ago. It's nothing. Just pull it off like they said and put the new one on. Took all of 15 seconds for me to do.
