how do i check the timing?
I recently put an msd optispark in my car, Is there any way to check the timing?
I know you cant adjust the timing on a stock opti but the msd has a little screw to play with it. |
Re: how do i check the timing?
Now you've discovered one of the MSD weaknesses. There is no "0" reference, so you have no idea where it's set. MSD suggests a certain number of turns out or in or something. To accurately check it, you would have to install a TDC mark and degree marks on your damper, hope the unkeyed damper doesn't move, and install a pointer on a water pump bolt to reference the TDC mark when viewed with a timing light.
In other words a major P.I.T.A. fred couldn't he use a laptop and datamaster too see timing at any given rev? Just food for thought. I know it shows my main spark advance at all times
for stock timing its 2 full turns counter-clockwise from tight. If you play with it too much it can rattle loose by the way.
Originally Posted by dennis5374
(Post 6800936)
Kind of a different subject but my car will be running fine then it just shuts off. It always starts right back up. Its done it to me driving and just at an idle. Whats up with that?
Im pretty sure the m.s.d has references as to what is what. So in datamaster what im seeing for timing is false because it lacks the ability too calculate for th opti-adjustment
Fyi: my original timing chain was stretched at 70k miles.
Originally Posted by donaldsz28
(Post 6801161)
Originally Posted by 2manyToyz
(Post 6801411)
same problem, i thought it was vats related turned out to be a bad icm
(Post 6801203)
So in datamaster what im seeing for timing is false because it lacks the ability too calculate for th opti-adjustment |
(Post 6801422)
I just put a new icm and crank position sensor on it a couple of weeks ago.
| All times are GMT -5. The time now is 08:03 AM. |
