How can I tell if my spark plug wires are bad?
SO how can i? It seems that half of the plugs are burning good, the other half or 3 are burning rich.. I Just replaced the plugs.. The car hesitates and has a bit of unnoticeable back fire, or so it sounds.. and the car back fires under WOT in first gear, after 1st gear its clean as anything, smooth and all... Just cruising around 2000 RPM it jerks around everynow and then, this never happened before, just started... Starts and idle fine.. doesnt seem to have any hesitation.. opti is brand new.. about 3000 miles
Take a long hard look at the wires in the dark and see if any of then ar arching, also check places where that wires touch anything else for burnt marks on the wire.
Dont forget to check the coil wire also
And after i changed my wires i noticed one would come loss from the opti every now and then so make sure al the wires ar on tight maybe unplug and plug them back in.
I had the worest time tring to get my coil wire on good behind the water pump
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
