Hotcam Kit, Rate my track times!!!
Old Apr 3, 2004 | 06:54 PM
ZPaul2Fresh8's Avatar
Lightbulb Hotcam Kit, Rate my track times!!!
I was wondering how my track times are compared to other people's out there
60 ft: 1.98
330 ft: 5.621
1/8: 8.579 @ 84.44
1000': 11.12
1/4: 13.27 @ 104.92
Those are my best numbers and here are my mods:
93 LT1/A4
Hotcam Kit
30# SVOs
Longtubes
Borla !CAT
K&N, LID
SFCs, LCAs
315 DRs
MSD 6AL & Wires
Tuning
And some spark knock
Dyno'd last week 320rw/331tq on Mustang Dyno, It seems my trap speeds are low
Old Apr 3, 2004 | 06:58 PM
stereomandan's Avatar
Well, the spark knock could be killing you. Also, with an A4, your traps don't look THAT bad, but maybe a couple of mph low.
Take care of the knock and see what you do.
Dan
Old Apr 3, 2004 | 08:23 PM
xxsaint69x's Avatar
dont let people tell you your time is up there.....There are tons of bolt on cars runnig those times and faster.... i would double check everything, there is something wrong with your car...esp if you dynoed 320 on the mustang dyno.
Marcin
Old Apr 3, 2004 | 08:50 PM
Thanks, Damn spark knock I think is getting me at Top End, maybe that's the reason for low trap speeds....
I'll Bring advance down a few degrees and see if that helps me.
I think the tranny is taking a crap... slipped on two runs @ around 5700...
Never endgin game of fix it
Old Apr 3, 2004 | 09:24 PM
WrecklessZ's Avatar
How about a stall
Should atleast be 13.0 or better with that setup.
BTW what kind of Drag radials are u running.
Old Apr 3, 2004 | 10:31 PM
chesee48's Avatar
i have a few boltons:
shortie headers, cai straight pipes, cutout, full suspension and stall w/ gears..
i ran a 13.2 at 105
Old Apr 3, 2004 | 11:50 PM
mkent's Avatar
it's not your car, it's Ohio! i swear, i've never seen or heard of a "good" track time from a car in Ohio. granted i do have 2.73 gears, my car averages 14.3-14.4 at 97mph stock. it has ran a best mph at 98.57 and a best E.T in the sig. my 6spd car ran a best of 14.38 @98.97 mph (all at National Trail Raceway). and everyone i've talked to at the track says their cars ran 14.2-14.5 stock depending on weather.
try again after tuning and see how it does, but i'm willing to bet if you ran it somewhere where the air is better your times would be significantly improved. i'll try to prove my theory this summer....road trip!
Old Apr 4, 2004 | 12:23 AM
Daryn95Z's Avatar
I have run a 13.7 @ 108 with everything in sig. Thats with a horrible 60 and missed 3rd gear on street tires.
My cam's not much bigger than yours and I have shorties.
I would say your trap mph is very low for you mods, your dyno too.
Old Apr 4, 2004 | 12:26 AM
rock1501's Avatar
All I can say about your times is ouch
Old Apr 4, 2004 | 12:29 AM
bunker's Avatar
All I can say is:
My cat's breath smells like cat-food.
for that horsepower you should be hitting better times, I bet its the knock.
Old Apr 4, 2004 | 12:33 AM
rock1501's Avatar
with that rwhp and torque you should be trapping 109 or so
Old Apr 4, 2004 | 12:34 AM
lastze4me's Avatar
All I got are a few budget boltons, see SIG.
I got nothing near a Hot Cam Kit and im running 13.11 @ 104.25
Old Apr 4, 2004 | 01:08 AM
bski224's Avatar
Whats up i just have hot cam and P/P heads and intake match, regular B.S bolt ons 12 bolt and true dual im running 12.50's @113 with a 60' time of 2.0 With supension work and slicks i know i can damn nearly hit 12.00 or like an 11.90's Something is not right with your setup. Did u get comp reprogramed
Old Apr 4, 2004 | 03:22 AM
96LT14u2Nv's Avatar
yeah, i think those times are pretty low even for a A4. i traped almost 6 mph higher with a slightly bigger cam and a A4. dyno #'s dont seem that far off though. weird.
Old Apr 4, 2004 | 07:12 AM
Originally posted by WrecklessZ
How about a stall
Stall eventually, after I fix all my little problems so I don't create anymore
315/35/17 BFG Comp T/A with 19 PSI...
PCM was tuned by PCM4Less, but what's wierd is the spark advance. In the Constants you can set maximum spark advance and it's at 46 degrees. Now looking at the timing table, I see some cells at 47!
I run 93/94 Octance and I've tried 100 Race Fuel with no help since I forgot to LOG! The only thing I can think of is fine tuning it. I'm definately recording knock in the 4000-4800/98 KPa ranges...
