Hot weather issue
Hot weather issue
So I've been searching for a while regarding my issue, my name is cameron I've owned three different lt1 based vehicles and quiet frankly I'm stumped , I have a problem where if its really hot outside and I drive for say 15 minutes I'll start getting a bad misfire at 2k rpm , not sure of the cause. Car runs perfect for hours when its not too hot outside . Opti was replaced 8k miles ago and so was icm and plug wires also new plugs. It's a 95 z28 6 speed , any info would help me
Re: Hot weather issue
can you be more specific on the temps you are having issues with? like 90* is bad but 60* is ok. My first thought is coolant temp sensor but I am not sure they are that sensitive to outside temp once its warmed up
If the ses light is coming on then you should be able to read any codes being set. Please refer to this link for Scan9495:
https://www.camaroz28.com/forums/lt1...bs-srs-874325/
Heat related issues like you describe usually scream either opti or icm. You said they were both replaced. Did you use a quality delphi unit? The knock offs are known to be poor quality. Of course, without a scan, that's taking shots in the dark.
Did you use thermal compound between the ICM and the heatsink? It would've been a good opportunity to space the coil bracket from the head. It's not uncommon for the ICM to become heat soaked and cause erratic ignition problems.
