High Torque Starter---
My new le2 package will be pushing a 11.8 : 1 compression ratio. Should I invest in a high torque starter or is the stocker going to be fine since we are pretty high CR already? Thanks ---
Re: High Torque Starter---
I personally wouldnt buy anything unless necessary. See how the stocker works, if it doesnt suffice buy an LT4.
-Dustin- |
I'm running a 396 w/ 12.2-1 compression and the stock GM starter works just fine.
WD http://www.cardomain.com/ride/2189634 |
my stocker on my 383 was fine...for a while. but it had 95k miles on it. i bought a lt1 stock replacement. when it fails i'm going with the lt4 corvette starter. they're smaller, have more torque and are cheaper...and you dont have to have a core.
For some reason my 11.2:1 383 ate/broke the cases on 3 stock LT1 style starters...I switched to the LT4 style and have been fine and it clears my Kooks stepped LTs...
--Alan |
Awesome, lt4 is where its at :) ---
My stocker is fine so far. I'm running 11.5:1 compression.
Originally Posted by Will84
(Post 4163620)
It's acting just as it did with the stock engine. I haven't noticed any change. It's been about a year since the swap.
Originally Posted by alwayscode
(Post 4165457)
Fine as in it works, or does it sound strong pushing it over? I hate hearing it wind down and barely pushing it over, lol. My 327 is going through that with the "stock" style starter . and its only 10.5:1 :) ---
Wow, technology rocks ;) Thanks everyone---
I actually was told no more replacements on my stock replacement starter because I killed so many of them in a short time with my 12:1 LT1. I switched to the beefier LT4 and haven't had a problem since. :thumb:
| All times are GMT -5. The time now is 03:10 AM. |
