High Torque Starter---
Old Oct 15, 2006 | 06:23 PM
AlwaysCode390's Avatar
Arrow High Torque Starter---
My new le2 package will be pushing a 11.8 : 1 compression ratio. Should I invest in a high torque starter or is the stocker going to be fine since we are pretty high CR already? Thanks ---
Old Oct 15, 2006 | 06:27 PM
Bersaglieri's Avatar
Re: High Torque Starter---
I personally wouldnt buy anything unless necessary. See how the stocker works, if it doesnt suffice buy an LT4.
-Dustin-
Old Oct 15, 2006 | 06:33 PM
The Engineer's Avatar
I'm running a 396 w/ 12.2-1 compression and the stock GM starter works just fine.
WD
http://www.cardomain.com/ride/2189634
Old Oct 15, 2006 | 06:57 PM
Severous01's Avatar
my stocker on my 383 was fine...for a while. but it had 95k miles on it. i bought a lt1 stock replacement. when it fails i'm going with the lt4 corvette starter. they're smaller, have more torque and are cheaper...and you dont have to have a core.
Old Oct 15, 2006 | 07:44 PM
ABA383's Avatar
For some reason my 11.2:1 383 ate/broke the cases on 3 stock LT1 style starters...I switched to the LT4 style and have been fine and it clears my Kooks stepped LTs...
--Alan
Old Oct 16, 2006 | 11:04 AM
Awesome, lt4 is where its at ---
Old Oct 16, 2006 | 12:35 PM
Will84's Avatar
My stocker is fine so far. I'm running 11.5:1 compression.
Old Oct 17, 2006 | 08:49 AM
Fine as in it works, or does it sound strong pushing it over? I hate hearing it wind down and barely pushing it over, lol. My 327 is going through that with the "stock" style starter . and its only 10.5:1 ---
Old Oct 17, 2006 | 09:04 AM
Will84's Avatar
It's acting just as it did with the stock engine. I haven't noticed any change. It's been about a year since the swap.
Old Oct 17, 2006 | 10:35 AM
anaik's Avatar
Your 327's distributor cannot back timing off upon start-up. Whatever initial advance you have it set to for max performance (20*) is there when you start. A PCM can retard timing when the engine starts. For instance, my scanmaster shows 9* advance when I start.
Old Oct 17, 2006 | 11:17 AM
Wow, technology rocks Thanks everyone---
Old Oct 17, 2006 | 02:05 PM
Sweetred95ta's Avatar
I actually was told no more replacements on my stock replacement starter because I killed so many of them in a short time with my 12:1 LT1. I switched to the beefier LT4 and haven't had a problem since.
DarkKnight
Exhaust System
19
Oct 17, 2016 10:28 AM
blmw
Jun 14, 2015 05:20 PM
KYWes
May 22, 2015 08:48 PM
May 21, 2015 01:04 PM
