CamaroZ28.Com Message Board
-   -   High idle issue (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/high-idle-issue-542878/)
DaddyLover Sep 13, 2007 10:29 AM
High idle issue
Would a broken Coolant sensor on the driver side head cause the car to idle high all the time around 2k like a warm up process? or is it another issue?
Thanks.
dangalla Sep 13, 2007 10:33 AM
sounds like a vacuum leak
mrmint69 Sep 13, 2007 05:03 PM
The sensor is only for the dash gauge and is not for any other purpose i believe. Does it idle smooth or does it vary or sound like a miss?
dangalla Sep 13, 2007 07:30 PM
is this true i was under the belief that the one in the water pump was for the gauge
