High beams don't work
Old Mar 22, 2004 | 01:13 PM
greensmoke's Avatar
I've had my car since she was 23K miles old, and the high beams have never worked. Five years later, I think it's time to quit procrastinating and fix it. Any sugestions? When I pull back on the lever, it doesn't "click", and even if I hold it, they never come on. Thanks in advance!
Old Mar 22, 2004 | 03:13 PM
You need to take the panels off under the steering wheel so you can get to the lower part of the column. The dimmer switch is located there. Move your lever and see if the rod to the switch is moving. The switch could possibly just need adjustment (the mounting holes are slotted) or need to be replaced. Don't disturb the position of the ignition switch that is held on by the same screws.
Old Mar 22, 2004 | 04:42 PM
greensmoke's Avatar
Thanks Shoebox, you da man!
LeftoverChinese
Jan 14, 2024 03:03 PM
Catmaigne
Dec 25, 2014 12:16 PM
ChrisFrez
Dec 15, 2014 03:09 PM
thenewkid
Nov 29, 2014 04:54 PM
siguy
Nov 27, 2014 10:07 AM
