high beam switch
Old May 22, 2013 | 02:56 AM
Chet1185's Avatar
high beam switch
Sorry for posting here, but I get no responses in the general tech section.
Originally Posted by Chet1185
On my TA the switch jusT flops around when I try to turn high beams on. Turn signals and everything else work. What can I check or replace?
Posted from Camaroz28.com App for Android
Old May 22, 2013 | 11:35 AM
Re: high beam switch
Provide more details on your thread in the general tech section. That is probably why you get no response. Hard to figure out if you mean the lever or the actual switch.
Old May 22, 2013 | 01:28 PM
Chet1185's Avatar
I would add more details if I knew anything about it. I don't know how it works or anything. You and I talked about it before but the car had sat for months so I haven't touched it.
Old May 22, 2013 | 02:59 PM
slick1hunting's Avatar
If its anything like my truck there is a switch and a metal rod to engage the switch. Mine had worn so bad I kept having problems so I just made the highs a toggle switch. What I have noticed is the turn signal deactivating mechanism is alot smoother in it as they can bind up in a turn and then you have to reef on the wheel to break them to not wreck.. Again this may or may not pertain to your car its just how it was on a 93 chevy truck.
May 21, 2015 01:04 PM
NewsBot
Mar 30, 2015 12:40 PM
Jan 23, 2015 01:13 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Catmaigne
Dec 25, 2014 12:16 PM
