Hi,new to site,can you help me out?
Hi found two of these in my 96 lt1 oil pan and have no idea what they are or where they came from,any ideas?https://cimg1.ibsrv.net/gimg/www.cam...59c83a8699.jpg
https://cimg2.ibsrv.net/gimg/www.cam...c0eb2910ef.jpgCylindrical,steel,look like roller bearings but from what? |
Re: Hi,new to site,can you help me out?
are those pieces of push rod?
Originally Posted by Chimera96
(Post 6998398)
can't tell in pic if those are hollow. If not, they are not pieces of PR
The relief pin in oil pump looks similar in size if it is solid. That is held in with a roll pin so quite unlikely that would come out...and there is only one of those in a oil pump |
Shaft from a roller rocker tip roller?
It is solid,It's to small for push rods and those I checked when I did the valve seals. It doesn't have roller rockers, I'm gonna guess the oil pump pin. The other one is smaller than the one pictured. Thanks for all your input
Originally Posted by Speedy96
(Post 6998409)
injuneers note on RR end roller pins would be way more likely but you say the 2 pins are different sizes.. If you are not original owner to the motor in the car...who knows WTF got dropped into or left inside motor before you got the car. Good you found it before something went bang or boom....unless that is how you found it. |
The sort of look like Camshaft/OPTIdrive pins. Maybe during an OPTI switchbthey got dropped into the pan...
I have all the paper work on the car since 2001 and the opti spark has been changed three times already so I spose that's quite possible,thanks
It would take someone to pull the pin from cam (not easily done at all) and that pin won't just fall out into the motor (timing cover) for it to then migrate down into the pan.....and twice. If it did fall into the motor on opti removal it would make MAJOR noise getting ground up in the timing gear/chain immediately on startup
I see way better odds winning the lottery than that happening If P.O. had intake off maybe whatever the small metal pin is fell into intake valley from careless P.O. |
Hi my name is felix and i have a 94 camaro and its getting hot on me. I changed out the water pump, the thermostat out but it leaks out of the coolent reservoir
Originally Posted by Felix Sanchez
(Post 6998527)
The “new thread” button is top left, above the forum topic listing. |
(Post 6998464)
