Hi mileage lt1 that are stock please!
Old May 3, 2007 | 06:55 PM
mrmint69's Avatar
I am looking for numbers for stock lt1's with roughly 90k to 130k miles. I would like to see what the average 0-60 & 1/4 mile times are if you fit the group. I made a 1/4 pass at 14.53 and my 0-60 time was 7.3 before i did my mods. I am trying to figure if this is average or how to gauge my engine alone since it is 100% stock with bolt ons only.
Old May 3, 2007 | 07:06 PM
2000GTP's Avatar
The previous owner of my car pulled off times ranging in the 14.7-15.2 range with 93K on the odometer in stock trim. When I took the car though, I found several things such as fouled plugs, old wires, and a couple exhaust leaks which I'm sure were responsible for the below average times. Other factors can play a part in your particular time as well such as track conditions and traction.
Old May 3, 2007 | 07:23 PM
er-z's Avatar
mine ran a 13.8 @100 mph with slp intake and flowmaster muffer
Old May 3, 2007 | 07:31 PM
AmericanMuscle33's Avatar
1.9 60ft, 13.84 @ 100.12...that was with 150,000 miles on a completely stock car. Otherthan, 275 series tires, K&N filter... Everything else was stock or OEM replacement (WP, Opti, etc).
Those were the good ol' days...
For comparison purposes, beware most of the people likely to post will be of faster times...(i.e. some people with a 15 sec e.t. may not exactly feel like sharing)
And btw...bolt'ons or 'ins means you're car isnt stock
That leaves one hell of a grey area...
Old May 3, 2007 | 07:48 PM
buzz12586's Avatar
In other words it wasn't stock
Old May 3, 2007 | 07:59 PM
landstuhltaylor's Avatar
the filter wont make much of a difference at all, and those 60 fts are in line with stock cars
Old May 3, 2007 | 08:10 PM
Nitelite's Avatar
Mine was an A4, mostly stock with the exception of 3 inch exhaust and a k&n filter, would run a 14.5-14.7. Shortly after I got it, found out the gears were 2.73. Since then I swapped out for 3.73s, some Nitto's, and a great tuning from pcm4less, I'm happy to say that I run mid 13s now
Old May 4, 2007 | 12:18 PM
stereomandan's Avatar
If the car was well maintained, there is no reason that it won't perform the same as it did at 10,000 miles.
Stock LT1 times are in the very high 13's to mid-low 14's. Trap speeds for a M6 are usually 98-101 mph.
0-60 isn't something most people can measure, stock it is 5.3-5.7 seconds.
Dan
Old May 4, 2007 | 12:26 PM
oneclean97z's Avatar
Dan
this is true, i make da** sure i get every oil change, trans, differential, tune-up on or before time, im hoping to break 150,000 and still be holding my ground well. im at 93,000 and the 0-60 mph test i ran i had about 6 seconds even but then again its my phone stopwatch
Old May 4, 2007 | 12:30 PM
Yeah, technically it wasn't stock. But it's close enough for comparison.
Woop dee doo.
Old May 4, 2007 | 01:44 PM
mrmint69's Avatar
I told the truth only because i have changed the car and it it much faster than stock. Otherwise i would take about a 1/2 second off the 1/4 time.
Old May 4, 2007 | 02:00 PM
buzz12586's Avatar
Woop dee doo.
Ok then, my car went 13.07 @ 108 stock.
Old May 5, 2007 | 01:37 AM
Style's Avatar
with 275 tires and an air filter??? Holy crap!
Old May 5, 2007 | 01:38 AM
buzz12586's Avatar
245 tires, CAI, catback
Old May 5, 2007 | 01:41 AM
Style's Avatar
wow. that is a pretty good time for those mods. Nice run!
