Here is a doozy! (no start)
Old May 12, 2005 | 10:11 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
http://web.camaross.com/forums/showt...22#post3059522
Old May 13, 2005 | 05:47 AM
slopokrodrigez's Avatar
Re: Here is a doozy! (no start)
If you're sure there is no spark, and you've changed all the ignition components, it's time to start looking at signals to see if they're there.
Start with the white wire going to the ICM. With a multimeter set to AC, when the engine is cranking, it should read between 1 and 4 volts AC. If not, ohm the wire from the ICM to the PCM. If so, check the black wire for a good ground and the pink/black and white/black wires for 12 volts. If that checks out, put a plug and wire on the coil and crank it over to see if you have spark there. If all the previous checks out and you still have no spark at the coil, it's DOA.
Nothing hard here, just methodical testing of one piece at a time.
silvermansteve
Mar 4, 2015 05:02 PM
eazyZ
Mar 1, 2015 07:12 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Amshnock
14
Jan 18, 2015 11:47 AM
Black Sunshine/ 00SS
Aug 24, 2002 03:41 PM
