help with valvetrain
Old Oct 11, 2005 | 02:04 PM
fastformula309's Avatar
Does anyone know what the stock rocker arm ratio is on a 94 lt1, Or the pushrod length and diameter. Also, if i wanted to go aftermarket w/ my valvesprings , rockers, and puchrods what should i use. I dont have much experience w the valvetrain on lt1s.
Old Oct 11, 2005 | 02:32 PM
OBE1 95Z28's Avatar
Re: help with valvetrain
Stock rocker arms are 1.5. Most guys step up to 1.6 rolling rockers. I like the Comp Cam Pro Magnums. The are not self aligning so you need to add guide plates. The 1994 cam with hardened push rods that will work fine with guide plates and the stock length is fine. I highly recommend you change valve springs to eliminate the potential of coil bind with the higher ratio rockers; the LT4 springs seem to do the trick.
Old Oct 11, 2005 | 04:02 PM
sssalah's Avatar
I like the pro magnums as well, if get them have them for 7/16" studs not the stock 3/8" it will be maybe $30 more (price of new ARP studs) and will give better stabilty and will serve better down the line with more radical mods.
The pushrods are 7.2" x 5/16".
HectorM52
Jul 30, 2017 11:46 AM
69z-28
Jan 29, 2016 10:46 PM
Noer
Feb 28, 2015 11:29 AM
MyShibbyZ28
Feb 14, 2015 12:05 PM
z28ponyeater
Mar 1, 2003 12:11 AM
