Help Timing Set.
Old Feb 13, 2006 | 10:54 PM
tritonium's Avatar
Help Timing Set.
Hey All
I think i ordered the wrong timing chain for my 1993 LT1 ( with 1993 opti)
I need to change the order tonight before it ships in the morning- please help
What timing chain do i buy?
Right now i have a CLO-9-3145 on order and i dont think thatl work, i also have a SUM-G6601 that i originally ordered ... I need help
What timing set do i buy please ? Part numbers so i can just call back summit
thanks!
It must work with 1993 opti and 1993 engine.
-Brad-
Old Feb 13, 2006 | 11:25 PM
Demon's Camaro's Avatar
Re: Help Timing Set.
I cant help you here but also have been wondering this for my 94(same setup). Ive heard that you can do a modification for the newer timing cover but have had no luck in finding a link to explain it further.
Old Feb 13, 2006 | 11:35 PM
Originally Posted by tritonium
Hey All
thanks!
-Brad-
You can't use either of those without modification. You must use a stock cam gear or timing set if using the stock, non-vented opti.
Old Feb 13, 2006 | 11:44 PM
tritonium's Avatar
got a part number for the stock timing set?
Old Feb 13, 2006 | 11:55 PM
Not to hi-jack the thread but is there any option for the non-vented opti or 94 and older cars in general?
Old Feb 14, 2006 | 07:41 AM
Check the part numbers link in my sig.
Old Feb 14, 2006 | 07:43 AM
Only to convert to a vented opti (which means changing lots of stuff-not too bad if you do it in conjunction with a cam swap).
Feffman
Oct 9, 2015 05:42 AM
barry76lt
Events and Cruise Spots
13
Jul 21, 2015 06:17 AM
ChrisFrez
Feb 1, 2015 08:26 AM
TitoPR221
Jan 2, 2015 03:51 PM
