HELP! Is there ANY outside difference between a 94-95 LT1 & 96-97?
Old Apr 6, 2006 | 12:22 PM
MikeTR's Avatar
Question HELP! Is there ANY outside difference between a 94-95 LT1 & 96-97?
Ok, I found an engine rebuilding company with a good price on a rebuilt LT1 for my 1995 Formula. $1925.00 shipped with a 3 year UNLIMITED mileage warranty Parts & Labor. BUT he says it shows a listing for 96-97 LT1 Vin P with Aluminum Heads. I THINK that they are all the same block wise and everything, just the dual cats I think is the only real difference between the two. Can anyone be of any help? Thanks in advance!
Mike
Old Apr 6, 2006 | 12:44 PM
Javier97Z28's Avatar
Moderator
Re: HELP! Is there ANY outside difference between a 94-95 LT1 & 96-97?
A 93-97 longblock will be identical one to another (there are some variations in head casting part #'s, etc that will not make a difference for your case).
Only diff it if comes with an intake is the 93 intake not having the crossover cutout for the fuel rail.
Old Apr 6, 2006 | 12:49 PM
MikeTR's Avatar
Talking Re: HELP! Is there ANY outside difference between a 94-95 LT1 & 96-97?
Nope, just the long block! Gotta transfer all my accesories over to the new long block. Thanks for the information. I think it's a good price. Used ones (with all the accesories) with less then 70k were going for $1400-1700! I think I'm better off this way with the warranty and all. Thanks again!
Mike
Old Apr 6, 2006 | 01:06 PM
Moderator
NP good luck!
Old Apr 6, 2006 | 02:54 PM
OBE1 95Z28's Avatar
96 - 97 LT1's have the crank position sensor mounted in the timing cover; this will work with a 95 as the 95 doesn't use this sensor. The crank hubs are a different length so if the long block doesn't come with the hub installed, you can't use your 95 hub (too long).
Old Apr 6, 2006 | 04:08 PM
MikeTR's Avatar
So, I'll have to get a crank hub for a 96-97? Is that going to cause any clearence issues with anything?
Mike
Old Apr 6, 2006 | 04:40 PM
97WS6SCharged's Avatar
It would be cheaper to remove the reluctor ring.
Old Apr 6, 2006 | 04:45 PM
GRNcamaro's Avatar
http://www.automotiverebuilder.com/ar/ar99928.htm.... i thought the timeing chain cover was diffrent on the 96-97
Old Apr 6, 2006 | 05:14 PM
CamPower's Avatar
I also agree.
Old Apr 7, 2006 | 09:41 AM
OBE1 95Z28's Avatar
The 96-97 hub is shorter as the reluctor, used for the crank position sensor, fits underneath the hub. As posted above, the timing chain cover can be removed, the reluctor removed and now your 93 - 95 hub will work.
Old Apr 7, 2006 | 09:43 AM
OBE1 95Z28's Avatar
Here's a drawing of what's going on from Shoebox's site:
http://shbox.com/1/engine_front_diagram.jpg
Ringmaster72
Dec 12, 2017 10:12 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
