Help removing motor
Old May 13, 2004 | 05:01 PM
zuluman13's Avatar
Help removing motor
I have to remove my motor from the top the car was in an accident so i can cut **** off if i need to but i need to get it out with an engine hoist not a lift.
Old May 13, 2004 | 05:24 PM
30696bird's Avatar
It will be alot easier if you take the intake off. I pulled my transmission and engine out at the same time. It was not that bad really. And also, if you take the motor and tranny out at the same time......REMOVE THE OIL FILTER!!! I learned that the hard way.
Old May 13, 2004 | 06:13 PM
95_LT1_6SPD's Avatar
what do you need to cut off? I just finished up a k-member swap with the motor in the car. I would look at removing the motor as a last resort.
Old May 13, 2004 | 06:15 PM
zuluman13's Avatar
Im sorry i should have worded it better im taking the motor out to put in a different car. I was asking how i can take it out from the top and saying that to make it easier i can cut certain things off to get it out.
StansZ28
Feb 19, 2015 07:39 AM
jayvar
Feb 2, 2015 10:00 PM
centric
Aug 15, 2002 09:04 PM
