Help! quick question!!!!
I'm doing tghe LT4 KM and I'm disconnecting my battery. What size socket is the negative terminal?
If you HAVE to avoid trying a few different size sockets...:D ...it took a 9mm for mine.
It is 8mm
My socketi s too long.....can I just do it with my hand real quickly?
Mine was too.
I had to use an open end wrench. The 8mm was too tight so I had to go with 9mm. You can try by hand, hope you ate your wheaties ;) |
I ended up using the 8MM.......the terminal was too loose, so the ratchet wasn't really doing anything because it wasn't lined up. So I used my hand just to hold the socket as I spun it. I did it, finally.
When I used a 8MM a few times it stripped mine, so I got some new bolts and now use a 5/16, it's a snugger fit.
I just tried disconnecting my negative battery terminal and the nut is stripped. I cant get it off...what should i do now?
5/16" will work.
| All times are GMT -5. The time now is 07:39 AM. |
