Help with pushrod lengths
Ok here is the situation.
I am setting up a new cam right now with 1.6 NSA rockers. I had my heads milled 20 thousandths and am running impala gaskets. my intake guides were worn, but the exhaust werent, therefore I ALSO had a valve job done on JUST the intake side, which I think made the intake valves seat slightly taller. (probably .025 or so). With my cam kit i ordered 7.150" length pushrods and they are too long. According to my length checker, 7.050" is optimal on the exhaust side (going by eyeball on the valve stem). No problems here. Moving to an intake valve, the checker shows 7.050" to be "OK" however 7.000" looks better. The problem is, a 7" pushrod makes the rocker bottom out on the stud just before it makes contact with the pushrod. it is not much at all, its just enough that fingertightening will not drag on the pushrod. I have to tighten about 1/4 turn instead of the normal 1/6 to set the lash. I need to order new pushrods obviously so what do you guys recommend I do? If the rockers werent bottoming out... is it possible to run two different length pushrods on intake/exhaust? Would 7.050" all around be alright? what do you guys recommend I do? I want to get this right. thanks VERY much ! |
Do a search on my user name and "valvetrain geometry" and you will find a ton of stuff. The concept of centering the pattern on the valve stem is BS.
Feel free to PM me if you would like more. |
thanks, sent you a PM.
I just ordered a set of 7.050 length rods last night so i can get it running this weekend...so i hope the centering method isnt that far off. |
Gona have to splain that one !
Originally Posted by truedualws6
(Post 5497143)
BTW http://compcams.com/technical/Catalogs/106-07/264.pdf |
Originally Posted by speedygonzales
(Post 5499383)
Could you elaborate on your statement please?
After reading all the mid lift stuff I realized that it's more important to have the narrowest swipe across the valve stem and the pattern being off center does not matter (within reason). So after spending all the time and money to get to 7.05" pushrods I went and did it all again based on the mid lift criteria. What I ended up with is 7.30" pushrods. In hindsight I could have just run the 7.20" pushrods and called it a day. That's why I refer to it as BS. I'll bet that 95% of the H/C LT1 setups can throw the detailed analysis out the window, run 7.20" pushrods, and be better off in the end. I don't want to see people waste time and money on this. Put in a 7.20" pushrod and see where the pattern is. If it's .080" or more inside the edge of the valve stem you are golden. In theory, a centered pattern with more swipe will put more side to side load on the valve stem than an off center pattern with less swipe (again, within reason). Here are some previous posts on the mid lift stuff: https://www.camaroz28.com/forums/sho...d.php?t=594453 https://www.camaroz28.com/forums/sho...d.php?t=599108 https://www.camaroz28.com/forums/sho...d.php?t=609026 |
Agreed. The more sweep there is the less lift there is. As long as the edge of the sweep is more than 20% of the valve diameter you are golden. ;)
I can also vouch for this.
25% is what I was told, but hell, that's only a couple thousandths difference! |
Hehe, I ran into truedual's first post about this AFTER I bought the 7.20" rods for my CC503....I thought crap....I may have too short rods because my heads are milled too. Then I saw the follow up posts and saw he went back to 7.20". I then thought whew!:D:D I wouldn't mind getting deeper into researching this...but based on his experience(for now) I'm going 7.20" and calling it cool.
Well guys I ordered the 7.050" rods and they dont even fit!!!! I end up with slack in the rockers after setting the lash. im at a loss, guess my measurement tool is pulling a fast one on me.
Here is some pictures of my geometry with the 7.150" rods: intake baseline: http://www.joeldevriendt.com/files/p...eline_7150.JPG intake midlift: http://www.joeldevriendt.com/files/p...dlift_7150.JPG intake maxlift: http://www.joeldevriendt.com/files/p...xlift_7150.JPG exhaust baseline: http://www.joeldevriendt.com/files/p...eline_7150.JPG exhaust midlift: http://www.joeldevriendt.com/files/p...dlift_7150.JPG exhaust maxlift: http://www.joeldevriendt.com/files/p...xlift_7150.JPG I think my intake at max lift is the most questionable. the rest look ok. |
I think you are in the same trap I was in. If you still have your stock length pushrods put them in on #1I and #1E and see what you get. Another item to measure is the number of turns you get on the locks. You want a minimum of 8-9 turns for 7/16-20 studs. This is usually the only downside to longer pushrods because as you lengthen the pushrod you raise the rocker and lessen the number of turns.
(Post 5499825)
And funny thing about the locks. 3 of locks on my rockers are sunk deep compared the rest (adjustment bolt is sitting higher) yet the rockers appear to be perfectly in spec :confused: |
Originally Posted by JoeliusZ28
(Post 5500363)
(Post 5499544)
What I have found is that a 7.20" pushrod, which is the stock length, will work for most H/C combos.
(Post 5500363)
if that was you that called me this evening i apologize, ended up going to a wedding.
(Post 5500675)
I bet the 3 oddballs have their trunions upside down. They should all have the flat side up.
But you saying BS was at first a bit confusing. |
well you guys were right about those 3, thanks a bunch i would have probably never noticed that!!
:cz28: |
Joelius, i guess im a couple days behind you in the installation, but i feel like im looking at the same motor. did you end up figuring out the correct pr length for yours?
