HELP!!!! P1441 Code Evaporative Emissions System???
Hi -
I have a question for all you guru Z28 gearheads. * I thought I was until this pesty little problem accured* Will removing the air pump out of a 96 z28 cause the Engine Light to pop on? My Air pump is burned up and after little research I was told it would not cause a engine light... BUT the engine light has stayed on after removing this air pump. I have had the computer reset also. Plus a little something that brings me to the air pump is the code * only code* P1441 code.. ~ Evaporative Emission ( EVAP ) System Flow During Non-purge Chevrolet Only ~ Can only out there help me? Please email me at jcashley@sbcglobal.net:confused: :confused: |
| All times are GMT -5. The time now is 09:53 AM. |
