CamaroZ28.Com Message Board
-   -   help needed badly!!! (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/help-needed-badly-164913/)
kdr_nrz28 Sep 1, 2003 09:24 PM
i was driving my car last night and hit a big puddle on the passenger side. suddenly my car was misfiring and stalling out really bad. it was still doing it this morning. i dont see how water could have gotten in the air intake so i am out of ideas. if anyone can help, please save my car (before i have to sell it!!!!)
nateh Sep 1, 2003 09:38 PM
One possibility is that you splashed water on your opti and we all know how they like water...
droptop1 Sep 1, 2003 09:40 PM
i agree with nateh. give it a couple of days to dry out and it will most likely go back to normal. you might get slight hesitations or stumbles everyonce in awhile though.
kdr_nrz28 Sep 1, 2003 11:41 PM
i hope that it is. not to doubt you guys, cause thats what i thought before, but i accidently drove through a flooded road up to the body once and it was totally fine. i just had the wires and plugs redone. so i hope that is it if anyone else can think of something please let me know.
RamAir95TA Sep 1, 2003 11:46 PM
My money is also on the demise of the optispark.
KwikistZ Sep 2, 2003 12:07 AM
Everyone should get LTCC:thumb:
:metal:
scoobysnax83 Sep 2, 2003 12:14 AM
:metal:
I totally agree. Next upgrade after my cam/heads/lifters/rockers/pushrods/headers upgrade next weekend (long weekend) will be the LTCC setup. Its such an ingenius Idea. I can't wait for it. Good Luck with the problem. But I vote OPTI as well. :( You do have a vented so that is a plus. Run it as much as possible to flow the air through there and prevent corrosion.
95z28 -quicksilver Sep 2, 2003 01:19 AM
i second the opti. Those things suck. I replaced mine. not too bad but it still sucks.
RamAir95TA Sep 2, 2003 03:25 AM
From the LTCC website:
Benefits of the system are:
-extended opti life
-much stronger ignition at high RPM/boost
-built in adjustable rev limiter / two-step
-built in adjustable N2O / boost retard
Sounds good to me. :)
