Help: Need help witha mis-fire.
I just replaced the OPTI, water pump, plugs and put in Taylor OVC kit. I also removed the air pump which I did not do when I installed the headers a month ago. It starts fine, but I have to hold it at a 2000 RPM to keep her running. I can stab the throttle and it is fine, but if I let it fall below 2000 it dies or if I roll the throttle up to 3000 it willmis-fire badly. Any ideas from you would be appreciated.
Thanks |
Re: Help: Need help witha mis-fire.
Plug wires crossed up?
Nope, I checked that. I am picking up a new coil tonite. I think that is it.
Will Update. Thanks for replying! Ryan |
bad maf?
try unplugging it...if it runs ok it indicates that is the problem. sure you don't have a hole in the intake someplace...like a ripped elbow |
I let it run for a bit and it pulled a MAF code so i bought a new one. I will not get to work on it till Wednesday, but i will update. I doubt it is a ripped elbow, but i will check.
Thanks Ryan |
| All times are GMT -5. The time now is 08:14 AM. |
