help me plz!!!!
whenever i start my car in the morning even if it isnt cold outside my car starts as if it where a dragster like cammed or somthing . uit takes a few tryes to start and idle is rought. i can also smeel some gas but i guess is becasue of the times i tryied to start it .could this be the opti or is fuel related?
help plz. thanks |
Mine does the same thing, but in every kind of weather and I have brand new ignition system.(opti, plugs, coil, wires)
Might want to have your starter tested.:confused: |
sometimes in rain it just wont start but the starter is new.
im hopping is the opti or just a fuel filter. |
plz help me.
I've got a new fuel filter too, but the same thing still happens.
You should try a new fuel filter (cheap/easy to change) and check the fuel pressure. |
is there any brand i should get ot just go to advance auto parts and get 1?
also how can i check my fuel presure? |
It sounds like you have an injector that is leaking.
It is let fuel to drain into 1 or more of the cylinders and flooding the engine. I would would put on a fuel pressure gauge turn the key on and watch the guage. It should read somewhere around 43 psi. Wait for the pump to shut off, then turn key off. Watch to see if the fuel pressure drops. |
in that case is it easy to change injectors?
also if it is an injector what brand should i get? |
lot of the guys I see in here are runnings SVO injectors, but most of their cars have alot of mods. I would run the stock size, other wise you will have to reprogram the ecm to run with the larger size injects. as of what brand, I'm not sure which brand to recommand. I hae had to replace any of mine yet. bosch, svo, or maybe accel. do not put use ls1 on a lt motor, becaause they are smaller injector do to the psi difference.
It also could be the fuel pressure regulator. |
thanks.
could this just be the opti? cuz i washed the engine not long ago |
Originally posted by cridom thanks. could this just be the opti? cuz i washed the engine not long ago |
Ruogh Start
I have read that the opti spark system for the 93-95 models had a flaw. When they get wet they run rough or not at all untill the system drys. The replacement opti spark systems have been fixed.
Re: Ruogh Start
Originally posted by elament I have read that the opti spark system for the 93-95 models had a flaw. When they get wet they run rough or not at all untill the system drys. The replacement opti spark systems have been fixed. |
| All times are GMT -5. The time now is 06:21 AM. |
