!HELP ME! Only take a sec LT1 know-it-alls! blown head gasket?! w/ GOOD Compression?!
Old Sep 26, 2004 | 12:47 PM
chevy5143's Avatar
Hey guys 4 weeks ago sister drove car started to smoke a bit then going up a hill lots of smoke. Now car wont start I try to start it spray gas in the intake get it strugles to run with LOTS of white smoke out exhast and TB! Thought it was a bad head gasket so I did a compression test all cylinders 120-150 lbs. Any ideas why smoke and no start? Could I have a busted head gasket with good compression? Is there a sesnor I need to check (new TB sensor, O2 sensor, and egr sensor/valve) HELP!!!!!
Old Sep 26, 2004 | 12:59 PM
Mindgame's Avatar
Re: !HELP ME! Only take a sec LT1 know-it-alls! blown head gasket?! w/ GOOD Compression?!
Could be that it only really leaks when under load. In that case it could be tough to tell with just a comp check. Leakdown might work better.
What about the coolant? Does it foam up?
What about the oil? Any signs of coolant in there?
You could also have a shop run an exhaust gas analysis.
If it's "white" smoke out the exhaust and the intake, then you definitely have a coolant leak going on and you'll need to pull the head(s) to correct the problem.
-Mindgame
Old Sep 26, 2004 | 01:13 PM
chevy5143's Avatar
I've checked the oil and i have found it to be milky but my uncle an older and wiser motor-head says that the oil didn't look contaminated to him. Any tips on pulling the heads to make the job easier?
Old Sep 26, 2004 | 01:20 PM
chevy5143's Avatar
Oh and is it still possible to have good compression even with a blown head gasket?
Old Sep 26, 2004 | 01:26 PM
Mindgame's Avatar
This website will help you out more than I can in just a post...
http://www.fierolt1.com/lt1_CamHeadinstall.htm
And yes, it is possible to have decent compression with a crack or some from of leakage that only really occurs when the engine is under load and/or at operating temperatures.
-Mindgame
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
