help with heads
Ok guys I posted about this on another forum wanted sum of your opinions! Have a 96 z28 with lt4 intake lt4 cam ported and polished heads. Im looking to add sum lowend power and was thinking of getting new heads and a cam or just heads. What setup do you guys recommend?
Gears and a stall if an A4 would help with the low end power. You should put the info for your car in the signature so we know more about it.
Low end grunt can be helped by long tube headers, and a cam with moderate overlap. You already have a cam that meets that description. The alternative is to raise the RPM as mrmint69 suggested.
| All times are GMT -5. The time now is 03:11 AM. |
