Help diagnosing engine trouble...
Since my head gasket repair last summer starting my Z in the morning has gotten harder and harder. The battery is strong, the starter turns over full speed but it fails to start. 4-6 cranks later it will start but stall right away. After a couple more cranks it starts and stay on. The colder it is the worse it gets. Thats problem number one.
This week I imagine the same failure is causing the car to want to stall WHILE rolling. It never stalls but its unresponsive to pedal movement, doesn't buck but does drop power, catch itself, return to higher RPM only to drop again. After about 10 mins, it returns to 'normal'. But even when normal, drivable condition, the sound from the engine bay is wrong. Almost a metal/metal vibration or strain on something that should turn freely. You can feel this in the car too. Almost like running into a strong wind, it isn't running effortlessly something is buggering it up. No SES and I don't have a scanner :( Car is at GM right now but if it doesn't happen for them they tend to move on. Ideas? |
Re: Help diagnosing engine trouble...
I was reading this thread:
http://web.camaross.com/forums/showthread.php?t=327206 and saw this: i had a new fuel pump installed a few months back (no problems with that, it cured my hard-start problem) jeremy |
Originally Posted by mmmchickenboy
do you have a way to check your fuel pressure?
i should have guessed a dirty fuel filter then... haha, anyway, good luck with that! later!
jeremy |
| All times are GMT -5. The time now is 08:57 AM. |
