Very weak engine
Old 09-26-2017, 04:09 PM
Shoedog's Avatar
Very weak engine
I just bought a 93 z28 manual trans. 70k miles. The car doesn't pull anywhere close to what it should. Struggles to rev past 3800-4000 rpm. It starts great and never dies, it's just weak. It is totally stock. Any ideas more than welcome.
Shoedog is offline
Old 09-26-2017, 04:46 PM
Re: Very weak engine
What happens when it hits 3,800-4,000 RPM - misfires, total loss of power, or keeps running, but just won’t go past 4,000?
Has it been checked for a plugged catalytic converter?
At any point have you scanned it for codes, or checked the fuel pressure?
Injuneer is offline
Old 09-26-2017, 05:46 PM
Shoedog's Avatar
The car runs past 4000, it's just sluggish. Revs build slow.
I haven't checked anything (bought it last night). I will start a checklist of your suggestions. Thank you!
Shoedog is offline
Old 09-26-2017, 09:56 PM
A weak coil can also cause weak performance.
shoebox is offline
Old 09-26-2017, 10:05 PM
Shoedog's Avatar
Is there a way to test the coil?
thanks guys
Shoedog is offline
Old 09-30-2017, 02:25 PM
Shoedog's Avatar
SOLVED. The fuel was over a year old. I drained the tank and put in premium. HUGE difference. Thanks for the input y'all.
Shoedog is offline
Old 09-30-2017, 02:48 PM
Chimera96's Avatar
consider changing the fuel filter now
Chimera96 is offline
