Help... ABS and ASR Light stay on!
The "ABS INOP" and "ASR off" lights stay on and no matter what i seem to do, i can't fix it. Can someone give some insight on how these to lights are related, and/or some suggestions on how to correct the problem.
have you tried just clearing the computer? pulling the fuse or disconnecting the battery? mine would turn on occasionally...all i had to do was clear the codes....and they would go away
try that
try that
try that
try that
Yeah i already tried disconnecting the battery overnight. I checked all related fuses that i could find either in the manual or on the fuse panel, and they were all good... i will check again anyways. About the wheel speed sensor, where is that exactly. I hate to take it in to the shop and waste money for just a small problem, i just cant figure it out.
Thnx for the replies.
Pull the light bulb, you won't have to worry about seeing that ABS INOP light again. But seriously, it happened to me, just the ABS INOP light. There was a loose connection going to my rear lights, pushed the connector together and wrapped in elec. tape and problem solved.
Ditto on cleaning the ground post by the red postivie cap (passenger side). Just fixed this issue with my buddy's '95. The stock ground post rests on a painted surface and relies on only the threads for a good ground connection!
I agree with Trey. My brakes started to grind in the rear and it made alot of metal particles. These attached themselves to the magnetic part of the speed sensor in that wheel. After I cleaned it and replaced my brakes, I had no problem.
