CamaroZ28.Com Message Board
-   -   Help!!!! A4 Is Now A2 (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/help-a4-now-a2-110269/)
frmula1 Apr 21, 2003 06:55 PM
i won't state when this started in detail (just an hour ago) because its lengthy and irrelavant...
this is what its doing....
it won't shift up out of 2nd...
in drive it wants to rev high into 2nd and then skip back down to first...
in "3" it will only go into first
it shifts perfectly, by itself from 1st to 2nd at like a stop light... but then when it gets to like 2500rpm it wants to go back down to first (this is at all throttle positions)
the only way to keep it in second is to manually put it in "2"...
what do i do? and what is wrong???
thank you so much for your help, in advance...
Injuneer Apr 22, 2003 06:47 AM
Generation specific posts belong on the appropriate "tech" forum, in this case "LT1 Tech".
Moving.....
MEAN LT1 Apr 22, 2003 07:52 AM
Re: Help!!!! A4 Is Now A2
Sorry to hear about your tranny isues bro, but to sum it all up, your tranny is toast and will need to be reuilt. Start saving cuz it aint going to be cheap.
kjlvilla Apr 22, 2003 09:32 PM
It looks like your 3-4 clutches are slipping and your 2-4 band is shutting off. This means your valves in the valve body are moving, shutting off the band for the 2-3 upshift but your 3-4 clutches are not holding. Your 3-4 clutches are probably burnt, with the 3-4 clutches not holding and the band off, you get 1st, or a 1 - 2 - 1 shift. Check your fluid, if its dark then you need a rebuild.
frmula1 Apr 22, 2003 11:36 PM
ok, i don't really want to rebuild... because of reliability/warrantee issues... would just buying a whole new 700r4 from gm be a good idea?
mr diabolical Apr 23, 2003 12:21 AM
www.pro-built.net
