Helllppp!!!
Old Feb 13, 2004 | 09:13 PM
96ta(nick)'s Avatar
Helllppp!!!
What screws into the head on the passenger side in between the back 2 header tubes? I started putting coolant in and discovered the hole.... HELP
Old Feb 13, 2004 | 09:25 PM
ibanez6rg's Avatar
Should just be a plug there... maybe you put the driver's side head on the pass. side.
Old Feb 13, 2004 | 09:44 PM
Tibbys96Z's Avatar
damn Nick, are you going to get that put back together before next winter?
Old Feb 13, 2004 | 10:40 PM
S.J.S.'s Avatar
its probably not a hole. Did you look at it. Should be an allen plug (I think) in there. Might just be leaking. How much coolant is coming out????
Old Feb 13, 2004 | 10:45 PM
CoUnTryMuZiCZ28's Avatar
Send some pics to me and i can tell you what it is.. Its probably the hose for the throttle bodie coolant..
EDIT:: This was early in the mourning... I was wayyy off.. lol.. yea coolant temp sensor...
Old Feb 14, 2004 | 02:24 AM
scoobysnax83's Avatar
No there is a sensor there, I believe it is the knock sensor, but it is 3:30 in the morning....So.....
Edit: I need to be smacked, thats the Temp sensor for the dash gauge, sorry....
I wanna go home....
Old Feb 14, 2004 | 05:05 AM
S.J.S.'s Avatar
yeah the temp gauge is for the coolant on the drivers side head. The knock module is located in the PCM. The knock sensor is on the lower pass. side of the block.
Old Feb 14, 2004 | 08:51 AM
ibanez6rg's Avatar
That's why I figured he put the driver's side head on the pass. side.
Old Feb 14, 2004 | 05:10 PM
I don't remeber posting that. I must have been asleep last night... Yikes, I swore that he said driver's side....
