Heating issues
I am having some heating issues this season. I turboed the car in the winter so there is alot more underhood heat but Still seems way to hot.
The car N/A ran 176* all summer, 195ish after driving for like 2Hours on the highway Stock rad/fans and electric pump Now the car gets to 230* after 20min of driving. Here is my cooling setup Electric water pump, dual puller 1600CFM each fans) Griffen 26x15.5x3 rad, 160* t-stat, Steam pipe is tee'd into the upper rad hose. Also my upper rad hose gets pressurized to! (I have check the oil and its fine) I have tried bleeding the cooling system many times too. Any ideas? The rad is holding pressure fine since when i lift the cap tab it goes into the overflow. Im gonna buy a new rad cap tomorrow maybe and see... Should I run a 16lb still with the griffen rad? Jay |
| All times are GMT -5. The time now is 04:33 AM. |
