heater hose sizes
Old Dec 15, 2005 | 04:01 PM
flusz28's Avatar
heater hose sizes
what size are the two elbows on the water pump on the passengerside from the two heater core hoses? one is on top by the stat and the other straight below it.
Old Dec 16, 2005 | 11:43 PM
94Z28WP's Avatar
Re: heater hose sizes
I used 3/4" hose.
Old Dec 16, 2005 | 11:44 PM
flusz28's Avatar
on both ends?
Old Dec 17, 2005 | 12:03 AM
94Z28WP's Avatar
Should be the same size.. I replaced the hose that's connected to the pump on the passenger side... I had to cut the hose where it was leaking and use a 3/4" hose barb to splice in the hose to the pump since the heater hoses are crimped onto metal lines along the body going to the heater core... Might be another way, but that's how I ended up doing mine.
Old Dec 17, 2005 | 12:06 AM
flusz28's Avatar
okay- i have the HAVC delete mode. i used a u shaped hose then used a piece of metal pipe and joined the two lines and it is leaking. so i just want to use one hose and get it done with. thanks
Old Dec 17, 2005 | 07:33 AM
Mtrhds94Z's Avatar
On this diagram off shoebox' site:
http://shbox.com/1/heater_hoses_93-94.jpg
# 7,3 and17, are 5/8 inch hoses [as is the upper hose fitting on the water pump]
# 12,15 and 20 are 3/4" hoses [as is the lower heater hose fitting on the water pump]
If connecting one to the other take a 5/8 x 3/4 connector and 2 short lengths of 5/8 and 3/4 hose to connect to the water pump.... some people cap those off with [ with like vacuum caps] that works too...
94Z28LS1toLT1
Feb 26, 2015 07:47 AM
dalynchmob
Feb 19, 2015 07:20 PM
crazypurgatory
Jan 12, 2015 10:45 PM
pologreen97z
Dec 2, 2014 10:42 AM
Jul 4, 2005 05:00 PM
