Heat Range
Old Aug 10, 2006 | 08:49 AM
383TransAm's Avatar
Arrow Heat Range
Well I have my car back from the shop and was given some sugjestions on Spark Plugs.
I have NGK TR-55's in my car right now but it was sugjested that I go to a hotter plug the NGK TR-5.
What is this going to do for me?
Old Aug 10, 2006 | 06:05 PM
96capricemgr's Avatar
Re: Heat Range
TR5 are the same heat range just a .035 gap instead od .050 gap.
Also that heat is great for a stock motor and is probably the most common plug used here especially on modified cars. That said I went from Auotlite 104s to TR55s on my car a week and a half ago and while it still pulls hard and all but it just seemed smoother with the 104s. The 104s I think are slightly colder than the TR5/55 so you might try them if you think you need a colder plug. In the NGK for nitrous and boost needing colder plugs the TR6 is the most common choice.
Old Aug 10, 2006 | 07:37 PM
383TransAm's Avatar
Re: Heat Range
Thanks!
I'm getting a carbon buildup on my plugs and with my setup I was told I wanted a hotter plug so the next step "up" from the TR-55 is the TR-5 so I'm going to try it.
Nayr
Mar 3, 2023 08:34 PM
CARiD
Sep 30, 2015 05:44 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
damnyankee36
Sep 9, 2015 07:06 PM
