| JAFO1994 |
Mar 8, 2003 07:41 PM |
I wish I could remember the site, but if you do a search for 'Camaro headliner' you will find a site that sells the liner foam and spray glue. I just did it like 5 months ago. Order the large. It was like $34. The only problem is the stock headliner has fiberglass sheeting and when you peel the old one off it tears the layers of fiberglass, leaving an uneven surface. I did mine and it's not entirely smooth. Has some divots, but isn't bad. The dealer sells new GM ones for $120 if you want a perfect one. I would recommend buying a new OEM one. Tearing the old one apart is very messy.
