headers and gaskets
my felpro gaskets dont want to match up perfectly to my pacesetters.
if the bolt holes match up then the D-port holes are NOT PERFECT and if the D-port holes are matched up the bolt holes are NOT PERFECT. however i think the gasket matches the head perfectly.........Defect?? or common??? if so will the part of the gasket thats in the way get burned off after a few hundred miles? or will it just foul out the gasket...............and i will have to replace it later..........what should i do???? Thanks, later |
Re: headers and gaskets
The felpros matched up perfectly with my Jet-Hots. I've also heard of pacesetters flanges not being straight sometimes, you might want to check that with a straight edge. Are you sure you got the right gaskets?
YUP |
i dunno, does it really matter???...................i already put the left one in because i figured thats how it was suppose to be and it would burn off later.
I REALLY dont want to take it off........but should i take it off and dremel the excess gasket off or just buy something else......like a percy metal gasket and use that instead |
I usually buy the Mr. Gasket ultra seals. I would remove the gasket and trim it with a razor knife, or try a different set. Who knows, maybe you got the one set in 5000 that went into the machine crooked. :)
I'll never use anything but Percy's dead soft aluminum ever again. :cool: IMHO, with the limited clearance in a f-body engine bay, I hate to do things twice. If a bolt backs out, a regular gasket burns through and you'll be taking it all apart to put in a new gasket. With Percy's, just retorque the bolt. ;) :D
| All times are GMT -5. The time now is 06:52 AM. |
