Header Primary Ports - Does it matter?
How much does it matter if the primary ports on headers match the exhaust ports on the heads.
Are headers with D shaped primary ports better than headers with Oval shaped ones? And If so how much better/worse? Does the D port gasket restrict Oval port primarys? Example: Rk Sport Mids and AS&M mids other than the coating the only difference in these are the port types AS&M is D shaped and RK's are Oval. Does it matter performance wise? Thanks -Dustin- |
The LT1 heads use D type ports, Although they would probobaly seal, I wouldn't use oval port headers on them.
Re: Header Primary Ports - Does it matter?
Originally posted by Bersaglieri How much does it matter if the primary ports on headers match the exhaust ports on the heads. Are headers with D shaped primary ports better than headers with Oval shaped ones? And If so how much better/worse? Does the D port gasket restrict Oval port primarys? Example: Rk Sport Mids and AS&M mids other than the coating the only difference in these are the port types AS&M is D shaped and RK's are Oval. Does it matter performance wise? Thanks -Dustin- |
So those headers with Ovals are ok to get? Performance wise? So RK's are about the same as the AS&M as long as you dont mind the coating?
-Dustin- |
Yes.
They are both great headers from what I've researched. Dan |
I am just using these as examples, I change my mind on headers daily. Today I want JetHot LT's:D
-Dustin- |
| All times are GMT -5. The time now is 03:20 AM. |
