Header Primary Ports - Does it matter?
How much does it matter if the primary ports on headers match the exhaust ports on the heads.
Are headers with D shaped primary ports better than headers with Oval shaped ones?
And If so how much better/worse?
Does the D port gasket restrict Oval port primarys?
Example: Rk Sport Mids and AS&M mids other than the coating the only difference in these are the port types AS&M is D shaped and RK's are Oval. Does it matter performance wise?
-Dustin-
-Dustin-
Re: Header Primary Ports - Does it matter?
-Dustin-
-Dustin-
So those headers with Ovals are ok to get? Performance wise? So RK's are about the same as the AS&M as long as you dont mind the coating?
-Dustin-
-Dustin-
Jul 4, 2005 05:00 PM
