CamaroZ28.Com Message Board
-   -   header emissions fitting ? (https://www.camaroz28.com/forums/lt1-based-engine-tech-9/header-emissions-fitting-324930/)
steves97z28 Dec 12, 2004 06:13 PM
i installed pacesetters longtubes with the emission fittings but ended up getting rid of the emissions. no i have the tube coming up off the header and i need a way to block them off. a local shop gave me these oil line caps they get on there race motors but they are made of tin and the treads blow off after a while. any help would be great, thanx.
Raped Ape Dec 12, 2004 06:19 PM
Re: header emissions fitting ?
If you are referring to the AIR fittings, I believe M22 oil drain plugs will fit those. You might do a search to make sure though. :)
steves97z28 Dec 12, 2004 06:25 PM
are they male or female? i need something that is female. i look into that though thanx
steves97z28 Dec 12, 2004 07:21 PM
anyone else? the oil plug is a male connector and i need female :confused:
