header emissions fitting ?
Old Dec 12, 2004 | 06:13 PM
steves97z28's Avatar
i installed pacesetters longtubes with the emission fittings but ended up getting rid of the emissions. no i have the tube coming up off the header and i need a way to block them off. a local shop gave me these oil line caps they get on there race motors but they are made of tin and the treads blow off after a while. any help would be great, thanx.
Old Dec 12, 2004 | 06:19 PM
Raped Ape's Avatar
Re: header emissions fitting ?
If you are referring to the AIR fittings, I believe M22 oil drain plugs will fit those. You might do a search to make sure though.
Old Dec 12, 2004 | 06:25 PM
are they male or female? i need something that is female. i look into that though thanx
Old Dec 12, 2004 | 07:21 PM
anyone else? the oil plug is a male connector and i need female
FredM
Exhaust System
Feb 18, 2015 05:37 AM
Jason Short
Jan 19, 2015 06:34 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
Firemechanic
Parts Wanted
Dec 14, 2014 10:22 AM
