header bolts
i just bout some used pace setter headers and i just wanted to ask out of this bolts which are the best and should i use treat lock is which treat lock blue or red and what gaskets ? http://www.sdpc2000.com/catalog/195/...olts-Studs.htm
Get you some 1" stage 8 locking header bolts part# 114-8911-A
http://www.thunderracing.com/catalog...vid=4&pcid=301 Then some Felpro gaskets part# 112-1406 http://www.thunderracing.com/catalog...&vid=4&pcid=54 I would get em all from thunder racing, you wont find a better deal on the gaskets, and dont use any threadlocker, get some high heat anti-sieze compund. |
Agreed on the above post, Stage 8 locking bolts and a set of Fel-Pro 1406s will do the trick and please do stay away from the threadlocker.
IMO stage 8's suck. nothing worse than getting a bolt tight and having to back it off to get the lock to line up. i'd go w/ ARP 1" stainless
I went with the above mentioned ARP bolts, and had no problems-I rechecked them after a few heat cycles to check for loosening, however.
No leaks yet! |
i used breslin locker bolts on my pacesetters and i love em. however bad news is i heard they went out of business :(
Originally Posted by 95LT1conv
(Post 4423563)
Anytime you thread a steel bolt into an aluminum head, you want to use antisieze grease as dis-similar metals will create a galvanic reaction and cause corrosion. Threadlocker is the wrong way to go; it doesn't stand up to temperature anyway.
i used the bolts pacesetter included with the headers. there had been no problems leaking at all in 10k and all i did was put anti-sieze on the bolts
I used the Pacesetter bolts and the copper gasket they supplied, no problems so far. I did have to tighten them up a few times however.
The best combination I have found so far is the Earls header gaskets and the Breslin locking bolts. This combination has been rock solid. No leaks :D
Originally Posted by 89TramsAmGTA
(Post 4424652)
Thats what I have. No problems so far. :) |
this 1ns look good what do yall think but wich 1ns the 1st 1ns or the second prt # 4667 or prt #4668
http://www.spectreperformance.com/#CATALOG.4668 check in the performance fastiners section |
| All times are GMT -5. The time now is 07:52 AM. |
