Header bolt holes stripped
Old Apr 21, 2014 | 07:39 PM
Stay Puft's Avatar
So i pretty much got lied too about this car. Was told "Its just an exhaust header gasket leak. No problems". Yeah... Head has to come off, get examined and i hope will just need to be rethreaded. Worst case i'll need a new freaking head.
Major issue with the the intake manifold as well. Tech thinks its leaking oil somewhere and doesnt match up well with the heads. Car is getting better and better
Old Apr 22, 2014 | 07:50 AM
pizzi-man's Avatar
Re: Header bolt holes stripped
HELICOILS would be the fix. probably got the bolts cross threaded and kept tightening striping out the threads.
Old Apr 22, 2014 | 08:40 AM
Is it a bolt in a location that precludes retapping for a larger diameter bolt, with the head on the engine?
Why does the "tech think its leaking oil somewhere"? Either he sees an external leak or he doesn't. Or does he feel the gasket is leaking, allowing oil to be pulled into an intake runner?
The most common intake manifold leak on the LT1 is at the rear of the manifold, where it sits on top of the block's "china wall". There is no gasket at that location. It's sealed with a bead of RTV, which dries out and leaks. Is that where yours is leaking? To check, take a paper towel, standing on the passenger side, reach back under the cowl, where the head, the block and the intake manifold come together. Wipe, and inspect the towel for heavy oil.
Old Apr 22, 2014 | 10:07 AM
RUDEDOG's Avatar
Try these. ++ TIME-SERT Threaded inserts for stripped threads, threaded inserts, thread repair stripped sparkplug's, Ford sparkplug blowouts, threaded inserts threaded, repair stripped threads, stripped threads, inserts threaded inserts, Ford spark plug repair,
Old Apr 22, 2014 | 12:21 PM
Stay Puft's Avatar
It's unfortunately not a single hole. It's multiple holes. It's the first 3 on the driver side and after doing some reading on the lt1 manifold leak this sounds exactly what my issue is.
Old Apr 23, 2016 | 03:55 PM
Gmcrazy1987's Avatar
Hey new to the forum thing but this is the only thing that pertains to me that I found I have the same issue bought the camaro when I got time to play with the exhaust my head was already had a stud in it but that one stripped the head can I retap it or will that make the surrounding area too weak
Victor Lamb
Aug 26, 2017 02:52 PM
RUENUF
Mar 13, 2016 03:39 PM
maybe2fast
Mar 16, 2015 09:45 AM
Joes96z
Dec 13, 2014 07:48 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
